How can I change my avatar to a GIF?
Taff
South West Wales
I'm obviously missing something. :blast I've found some brilliant GIFs but for some reason I can't get them to work as an avatar.
Every time I post the code it comes up as an "Invalid File". :nenau
Because a gif is two or more images, the size of the files are a lot bigger than a normal .jpg etc......you've got a max size limit of 110 by 110 pixels or 48.8 KB- I'm guessing the one you're trying to use is bigger than 48.8kb?
Right click on it and select properties- that'll tell you :)
