How do I change default settings on MS word documents?
Monsieur
Flâneur with style, passion and real substance
London/Lincolnshire
I've got word 2010 and I want to have a particular font and line spacing as a default setting - how do I do this?
  1. If you do not have a document open, create a new document that is based on the Normal template. To do this, click File, click New, click Blank Document, and then click Create.
  2. In the Font group, click the Font flyout.
  3. Select the options that you want to apply to the default font, such as font style and font size. If you selected specific text, the properties of the selected text are set in the dialog box.
  4. Click Set As Default.
  5. Select the All documents based on the Normal.dotm template? option, and then click OK.
Thanks :thumb2
I think I managed to sort out a minute before you replied but in a slightly longer way round than yours above :rolleyes:
