How do I do specific search
Dennis the Menace
Manchester
This is my problem. When going off road on my 04 12. There was a sequence where I could turn my headlight off. Maybe something has changed but using the same sequence I can't turn my headlight off on my 08 12. Where I am going tomorrow I dont want the headlight on.
When I want some information i always try to do a search. The only word the search is picking up is lights and there are 11 pages to go through. This is what I am typing in. How to turn a headlight off a 12 GS. Is there an easier way to do a specific search. I have done an advanced search and the same thing happens.
Dennis - later software on this bike (ie ZFE unit) no longer allows you to do it.You can perform the usual steps to stop the headlight coming on prior to starting the engine but after a couple of seconds the light comes back on. "Vorsprung durch technik", oops wrong firm !!
not sure if it works on later bikes but the early ones are as follows
Turning the Headlights OFF
The procedure is as follows:
Turn the ignition on and allow the startup-check cycle to complete. The headlights will be off (this is normal).
Hold turn-signal cancel switch for 4-5 secs.
Hold right turn-signal switch for 4-5 secs.
Start engine.
Lights should remain OFF.
You can also do this after the engine starts but only if you havent moved the bike..
About searching: If you go into the 1200 forum, there's a button at the top right, just below the bit where it says "Welcome, Dennis Crompton, blah blah blah" which says "search this forum". That'll just search the 1200 forum so no need to type so much.
Also there's not much point in including words like a, and, just use keywords. in fact I don't think it searches for words under 4 letters long anyway. I typed "headlight switch" into the search this forum box, and there on the 2nd page was this clicky.
hope that helps :thumb2
Edit: Oh I see that you've probably tried that technique, sorry can't help much more than that!
To get best results from a search, you need to use Boolean search methods....the use of 'and' 'or' 'not etc.......
If you did a search on 'headlights turn off' and it came up with hundreds of results that you didn't want to do with HIDs and headlights for example, you could search for 'headlights turn off not hid' (this needs messing about with 'cos I can't show the triangular brackets that you'd need)
Try this page for a better explanation :)
Turn Headlight off
So, is it posible to put a switch into the circuit to turn the lights off when you really don't want them on? Anyone done this or any ideas? I'd love this facility on my 08 bike.
Just as a matter of interest, why?
Why on earth would you ever want to turn them off? :confused:
I was once observing a guy for the IAM. He didn't know the route, so I had to signal the turns while following him (it checks they're using their mirrors too). I also had to flash him if I wanted him to stop etc. The problem is that with the soft suspension the lights were bobbing up and down all the time. The guy was struggling to tell when I was flashing from when I was riding over a bump. He also struggled to make out the indicators from the headlight. Following this I decided to find out how to turn the lights off.
I agree that most of the time its best to leave it on, but in daylight with good visibility then its useful to turn them off if they're causing more confusion than they're helping (two bikes are pretty visible without lights in broad day light).
Oh and the 06 is the same as colinw said, sorry don't know about the 08.
TobyS
On the pre '08 models you could turn the lights off by pressing and holding the indicator cancel button for 5 seconds or more, then release and press and hold the right turn indicator button for 5 seconds. The bike had to be stationary for this to work. To turn the head light back on again, either turn the ignition off and back on, or just press the high beam flash button.
This still work on the '08 models, but with an added twist: As soon as you start moving, the light comes back on again; it doe snot seem possible to run the bike with the headlight off.
Adding a switch into the circuit would work, you would need to cut into the loom before it enters the headlight unit; but would generate a LAMPF error when the light is turned off.
Thanks City. I guessed that putting a switch into the circuit might confuse matters. At least I know what to expect.
Oh, and there's many good reasons why you don't want headlights on all the time but last time I asked and explained I caused such a moral outpouring from some of the more vocal members on the site it fair put me off (the site, that is). Didn't realise that amongst the knowledgable there are some right pr**ks on here.
And with that I'll disappear again........
And with a poof, he was gone.
:confused:I asked (politely) why you would want to turn them off and suddenly I'm a prick?
Probably a good idea that you do dissappear ;)
:)For all you "headlights On" Die hard fans, and everyone is entitled to an opinion, dont take it the wrong way.
Try some filtering in town and you will find motorists a lot more likely to move over for you without your lights on, you appear less intimidating and because you are not blinding them in their mirrors, they can actually work out you are a bike and let you past, when they are blinded, especially in the os door mirror they will go into frightened rabbit mode and freeze.
Before you scoff try it, it works, this was taught to be by a highly decorated bike cop, and is something i always pass on to my associates even though the IAM recommnds lights on all the time.:)
Dennis - later software on this bike (ie ZFE unit) no longer allows you to do it. "Vorsprung durch technik", oops wrong firm !!
Thanks for the explanation
Thanks for the confirmation
The same reason I dont have a noisey can, I like to be discrete.
The same reason I stop for horses and riders, I like to be discrete.
Or stopping for walkers, rather than showering them in stone, mud and noise. I like to be discrete.
Most of all, so walkers half a mile a way can't see my headlight when I fall off into a ditch. I prefer to fall off discretely.
It a matter of choice!
And here's what I said last time
There's plenty of credible research that shows that motorcycles running with lights are a problem. There's two main issues.
1. A car driver judges the speed of approach of an oncoming vehicle by the rate that the vehicle "gets bigger". If its a car approaching it's fairly easy to estimate, the width of a car gives a big enough outline to be able to see this clearly. A taller, narrow bike is much more difficult - the bike does not appear to grow as quckly. This is one of the reasons why cars pull out on you. Now put your headlight on. You destroy the outline of the bike and make it almost impossible to judge the speed of appraoch. Safer? - I think not.
2. Add in a bit of risk compensation to the mix and you're well and truly in trouble. If you believe that the car driver has seen you because you've got lights on then you will unprepared to take any action if he does pull out. The car driver on the other hand may well have seen you (or at least a light) And guess what? Risk compensation plays a part again. He believes that you are not a danger to him and so he will go anyway. He can see it's "only" a bike and so WTF, he's protected. Ever wonder where the Volvo jokes came from? "I'm in the safest car, you can't hurt me even though I drive like a tw@t".
I'd rather ride without headlights in good conditions thanks.
And since then I've remembered that I can't drive through the Mersey Tunnel without breaking the rule "No headlights in Tunnel"
Colin, I believe you're right that most car drivers think that daytime headlights are threatening. Seen as shouting "Get out of my way" rather than "Here I am"
Lastly, Police reports from 2005 show that 50% of accidents are associated with either failed to look or failed to judge others speed. Headlights really can be part of that problem. Much more research needed I think and not just back of fag packet thinking it's a good idea either.
Sorry for the "PRICKS" quote. Feeling a bit out of sorts this morning when I wrote that. This is just something that I feel strongly about and last time I asked the question I also got a "right talkng to" from peple on the forum that really put me off. I know that there's bound to be a wide range of opinions with such a number of people but I reserve the right to take a strop with anyone who doesn't agree with a grumpy old git like me.
Again, sorry for any offence.....
None taken Johnno....
Couple of comments though-
I can fully understand the idea of a light, particularly a bright one, causing problems with speed/distance perception.
To me though the more important factor is that they at least know I'm there- I will still ride as if I'm a) Invisible and B) that they will do the most stupid thing they possibly can at the most dangerous time for me, but if they know I'm there, that's a start.
There are many statistics that people quote, and most are misleading.......I don't remember the numbers, but when it became obligatory for all cars to use headlights in Sweden (I think) , the accidents dropped significantly- hence the reason Volvos all have lights on permanently.
Someone above also claimed that people allow bikes through quicker when they had no lights on......If I wasn't such a polite person I'd say that was utter bollocks and totally contrary to my personal experience- As long as your lights aren't dazzling someone enough to cause them resentment (and if you do a clever enough search here you'll find me saying to certain twats who ride with teir full beams on that I would deliberately block their progress because they are anti social twats) then you'll be noticed and the vast majority of riders will report that they make better progress through cooperation with (sensible) lights on than with no lights.
I stand by the roadside an awful lot in Morocco, waiting for 6-12 bikes to come through to take pics of them- Those with lights on (as we ask them to ride) are many many times more noticeable than those who occasionally forget, and pedestrians, scooters, kids and car drivers will also see them coming far far earlier- it's up to the rider to make sure that any confusion caused by the valid point you make about the perception of speed being masked by a light is negated by the final approach to their hazard....the main point is though that they're seen, people know they're there!
The odd and presumably unenforceable rule about the Mersey tunnel and no lights- well they can fekk orf, numpty scouse plonkers :rolleyes:
That was me !! I also said dont knock it till youve tried it, It DOES work, you are of course respectfully aalowed your opinion, but try it first.. I had the same opinion as you untill it was demonstrated to me, its like night and day :):). Give it a fair shot and come and tell us all the outcome.
Who let you back in:augie:eek:
Good to see you again yesterday:thumb2
Possibly its an age related thing. I was brought up on user discretion "on or off". In 2004 when I got a 1200 that discretion was taken away, but I am still happy and confident to ride a bike in traffic conditions without a headlight on!
For relative new comers to motorcycling, they have never had that luxury.
