How much do your insruments shoogle
Den
Scotland
How badly, or at all, does your instruments/ screen shake when going over undulations, ( wot a big word, Im educated me ) bumps, for the stupid folk.
1150GS.
Mine shoogle like a pair of tits in a T shirt.
Ive tightened up everything obvious. I know they are rubber mounted but its a bit extreme.
Den,
Not a lot, fairly steady on this one, but my other one as you say tits in a tee shirt, seems to be variable, and no concise reason why.
Pete A
Wish mine looked like tits in a tee shirt, I might pay more notice to the speedo if they did ;)
had it all to bits to try make it better, unsuccessfully.
Since finding out that some peoples are more rigid than mine, I will try again.
Grandmother of 10 children and 40 grandchildren without athletic support during the London Marathon.
But I don't worry about it too much.
steady as the proverbial rock.
of course that's the ultra cool and sperfast BLACK ADV
Not a bit. As stiff as....
Now me head in the wind buffet, that is a different story. You sure your head is not like Noddy's too?
Well, Ive been investigating and got a few theories.
No loose screws, no cracked plastic. mounting frame ok.
the only thing I could find was that the indicator mounts could be slightly tighter, and my main suspect, the tank wasnt tight against the rubber bits between it and the beak.
I will try it tomerrow and see if there is any improvement.
You insult me sir., Unlike some people, I know wot im doin.
Den said:
had to try to make it better, unsuccessfully
since finding out that some peoples are more rigid than mine,
Could it be age related??:P
Engine bars
Den,
Try yer engine bars next to the frame, can but not always, make a difference.
Pete A
The shakes
Mine rattles and shakes too - have tried to track it down unsuccessfully - let me know if you have any luck?!
Beefikeefi
I found out on low revs there is a rattle somewhere in the front. I found out that the lights does not mount securly and that is what makes the ratteling sound.
Slippy
blue box looks like a netgear router.
Perhaps its net connected by wifi and Den gets UKGSer on the move.
Have you got a monitor bolted to the clocks ?
