How to hold your Chunnel or Ferry ticket…
EVskiy
Handcrafting clients ideas in real time
Hertfordshire
…unlike cage drivers, us motorcyclist do not have (well we do, but…) a place to hang the ticket from our rear view mirror stem.
Instead we get presented with our ticket, and two strips of sellotape. Fair doos if:
  • A: The day we travel on is nice and dry. We all know, that in the wet, the sellotape has as much sticky effect as would not having any in the first place.
  • B: A tosser*, sat atop of his awesome steed, is actually able to reach around his wind screen to attach the thing and the sellotape that is now folded on itself, whilst flapping about in mildest of breeze.
@Wapping seem have pioneered the idea of attaching the ticket with a (first iteration from memory) household laundry peg.
These however in my experience generally have not got strong enough spring nor have deep enough jaw to keep hold of the fairly large piece of paper that is a ticket and thus are prone to pinging off into the path of a vehicle that happens to be driving along side of you, at the slightest of bumps being ridden over.
Wapping’ latest (second iteration) idea, is to use a peg stile woodworking clamp(s). These are fairly cheap, come in a set of multiples of 2, 4, or 6 and are available from any DIY or popular hardware stores, large online retailer or that auction site.
On his recent trip to northern France, he indeed used three (yes 3 of them) one for holding a ticket, the other to hold his passport between the border checkpoints. The third (here assuming) is to hold his gloves whilst traversing the no-man’ land between said checkpoints.
These clamps will have a far superior jaw depth, easier to operate with or without gloves on or indeed cold and wet hands, not least as these quite possibly have a fair bit stronger spring to by default.
But even with a single clamp, the clamping pad (orange bits) is only a bit of indented/textured plastic, are fairly small, and possibly prone to being easily knocked or affected by airflow/wind, thus resulting in uneasy and potentially distracting ticket shifting whilst riding a motorcycle about the port/terminal grounds, with number of likeminded travellers surrounding you, the concentration should be focused on riding, and not on a ticket slipping away in slow motion.
As mentioned earlier Wapping has had (yes had) three of these clamps linked with a bit of cord.
He has indeed since binned the idea, upon returning from his jaunt.
I am assuming here that having his ticket clamped to the windscreen, and having a hefty pair of gloves and a passport dangling on the opposite end, may have resulted in rotation and a much faster clamp removal from the windscreen. I am after all assuming here, so the man himself will have to confirm so, should he wished too.
Now then, here it the best bit.
I have by a sheer accident come up with a far superior solution 😊, thanks to my dear darling wife.
A few years ago, she had purchased some ankle boots, from one of the high street retailers. These did come linked together with one of these rather wrong and reinforced ‘pegs’. So I’ve seized the opportunity to keep it. With her being rather curious as to why?
It is a peg of sorts, that has two sets of clamping pads. It also had a plastic hook (similar to a clothes hanger), which I did cut away to minimise the overall size of the thing. In hindsight, I should’ve keept it, as the hook was made of same rigid/reinforced plastic, and would’ve been an ideal solution for hanging my (Held Air&Dry) gloves that simply link together with a strong metal popper. Hey ho.
However this isn’t the best bit about this ‘peg’, but a simple fact, that the clamping pads do have medium density rubber insets. Each being approximately 2cm x 1.5cm in size. Meaning whether your windscreen is dry or wet, or if you happen to be traveling in gale force winds, the ticket will stay put as well as not be able to rotate due to dual clamping points.
Here, I have placed a pound coin next to the rubber pad.
Here you can see the location of now carefully removed reinforced hook.
The complete ‘peg’ is around 6.5cm long x 6.5cm wide and 3.5cm high at the spreading pads. The hook would’ve been approximately 6-7cm long overall.
I have now successfully used this peg on a number of Ferry and LeShuttle crossings. I normally keep it in my tank bag, then use it during the crossing. However, there is no reason not to ring a permanent place for it, within an easy reach from the saddle.
So boys (and girls) next time you are shopping about with your other half or indeed a friend, keep an eye out on one of these 😉
Bon voyage as they say and keep it rubber side down.
Ev
Just stick mine in my map pocket of my tank bag. It’s only really the guy that feeds you into the lanes that needs to see it, I just pull up next to him so he can see it.
Exactly, the purpose of which is smooth transition through the port…
… minimising delays and without being a selfish tosser, whilst holding up a que of fellow tossers behind you and the rest of cagers, whom are now risking missing their crossing 🤪
On one journey my 1600, the entry ticket thing pegged to the windshield, a hi-viz youth, shouted at me:
“Oi! Where is your boarding pass, mate?”
I stopped and pointed to it.
He: “I can’t see it from where I was”
Me: “Then stand, gassing to your mate, somewhere where you can”
I fell for the Touratech branded ‘Tactical Critical Document Retaining System’ or TCDRS.
only £75 so well worth it
Sent from my iPad using Tapatalk Pro
Eh….I don’t recall ever having a que behind me by the time you get to the lanes. The ques are at the passport checks, only one at a time tends to leave there to head through to the lanes. So no, I don’t Hold anyone up. Apart from which, wheres the issue, once in the lanes it’s usually 20-30 mins waiting before the barrier lifts anyway.
Large, small, very small, huge or just run-of-the-mill medium?
I was severely reprimanded for holding my passport in my mouth whilst digging something else out of my pocket. Not long after Covid restrictions had been lifted so I guess everyone still twitchy about contamination.
Yes and the cross infection measures, that we were taught , should continue , but don’t . Your passport could be contaminated by Herpes Simplex, for example , as you hand it over to the beautiful customs girl . Cruel , theoretical , but just making a point.
😬 Ouch, would be a tad to scratch for my tinted windscreen.
Jesus tosser, the comment that I've made, 'tis a tongue in cheek a poke and a prod sort 🤪. Don't let your piss get to a boil stage. You do as you wish to, or indeed see fit and what ever works for you, :rolleyes: for all I care, you may wish to stuff your ticket thingy down your builders crack :thumby:.
The post isn't solely nor squarely aimed at you, as the only member of the audience on these very pages. Some might (as have I) see Wapping' little "invention" as a useful solution to their yearly troubles and/or mishaps at the tea huts and less than amused occupants, whom have barely rolled out of their nappies and seemingly operate on nothing more than mundane dose of autopilot, for 8-9 hours a day.
All I know, is this. When I see a faffing tosser up ahead who's selfishly and completely unawares holding me up along and my six biker mates, whom are on a very tight schedule to get to the nearest watering jug, rather pronto, then I start talking to myself in a rather very vulgar language 😃, so be warned and watch your mirrors.
Bon Voyage! Le Tosseur Britanique!* Vava Voom :thumby:
*I only pretent to know some French, so merely imitate, Please do not judge me. Gracias Mongetout ;)
This takes pegs to a whole new level.
The built in rubber’ised jaws alone and the stiff spring, makes it a world beater. Use your peg, with pride.
img_1920-jpeg.319213
Yes, my unthinking mistake and it was a Man.
It has got me wondering whether I should upgrade my peg. Maybe to this, which also has a rubberised grip part AND a hook
Or maybe the ‘dual’ model?
With a bit of gentle persuasion, I am sure the ‘dual’ model could be taken apart and the hook rotated downwards. The single model too, perhaps. Though that appears to a rounded hook, which means it should simply rotate, in a very pleasing way.
Via the power of an imaginative Google search (it beats, “Got a link, mate”) I have found something pretty similar to our Eastern European friend’s shoe hanger thing.
The only downside, is that they only offer them in batches of 700 or 1000.
I will now set about visiting assorted clothing stores, as I bet they throw hundreds away each day, polluting our rivers, streams and oceans.
It is not until you start investigating fully, that you realise that there is a world of hooks out there.
The only downside, is that they only offer them in batches of 700.
Voila!!!! Almost identical! Jolly good!
Health to enjoy it!
Still, as you plan, and as I have done, we shall make a lasting contribution towards saving a planet from yet another piece of plastic going into the landfill what not to like and it created a talking topic on these very pages, even if it is boiling select tosser’ piss 😃
PS: could you please grab a couple, a few, as omitting a hook from mine has caused me now upmost distress, knowing that I could’ve hung my gloves of it for the past few years and not having to tuck them under my thigh, for fear of spilling them in a following tossers path, spelling a (possible) sudden end to his well earned jaunt. :thumby:
I am grateful muchly well in advance Mon Ami.
