How to refit gaitor into caliper, Non GS
ELIMINATOR
Hampshire.
I've got to refit the rubber gaitor into the sliding part of the caliper.
(the sliding pins fit into this) How the hell do I do this? Each time I try to push one bit in, the other side pops out. It almost appears to be oversize.
This is on a Yamaha 900 Diversion.
Is the gaiter new , if its a used one it may have been contaminated with oil , wd40 or grease and then they are just about impossible to refit as they stretch. Have had the same problem in the past with a few Suzuki's, also check for a build up of corrosion within the caliper body where the rubber fits as it will expand the gaiter enough to stop the pin fitting.
Used one:thedummy
I think I'll try various sizes of drills fitted in the bore of the sliding pin. Choose one that is not much smaller than the I/D of the gaitor, and see if I can stuff the gaitor back in.
