Tried using one of those Sony walkman radios on the bike last week. Only trouble was the amount of HT noise. Has anyone any experience of fitting a radio suppression kiit, or similar, to overcome this problem?
hey speggo dood
if your system is the same as mine its not the ign that needs supression its your injectors!!
i use a sony walkman and thought the same but in the end i found that when shutting off the throttle for a short period of time the interference would go away. then return .
after a while i came to the conclusion that its the injectors as they are cut off on overrun when the throttle is closed off to allow the engine to slow...the injectors dont inject....
am i making sense?????
hope it helps..
