Husky 701 accessories port location
GSite
Nr Sleaford, Lincolnshire, UK
Hi all you Husky experts,
Looking to connect Sat Nav to 701 Enduro (2021).
Does anyone know if the bike has an accessories connector with switched live feed and it's location ?
If so which type or is it a specific Husky connector ?
Thanks.
If you are going to be fitting heated grips at some stage....you may want to consider splicing into the USB feed for the sat nav power, as it doesn't use a lot of power. And save the ACC1 for that....
Or just buy a y-splitter cable to give you two ACC2 ports without having to alter the OEM wiring
