I feel like a bomb disposal officer - Red or Brown?
  • Thread starter Thread starter muddymoose
muddymoose
Please no double-entendres!!
I've got a Starcom1 and an 1150GS - but I'm a complete numpty!
I think the bikes got an auxillary socket near to where my left leg would be. It has a brown wire and a Red wire coming out of it. I think this is suitable for plugging in the Starcom to BUT....
1) Is it the right 'supply' to do it with (switched/Not switched)?
2) Which ones positive and which ones negative?
3) If I tap into the wrong one will it all blow up!
I look forward to receiving some wisdom in the matter!!!
Andy
The socket should be live all the time....use a tester to prove this.
The socket centre contact should be Positive....use a tester to prove this.
The socket outer contact should be Negative...use a tester to prove this.
The Red wire should be Positive.....the Brown wire should be Negative.
Again,use a tester to prove the above...or look to see where the wires are connected.
In your appliance power lead,if both cores are black but one has a white 'trace line' on it,then that is Positive......this is standard practice.
The Intercoms that I`ve wired up for people have required a switched feed,so the socket wouldn`t be suitable in those applications.
Connecting up with a reverse polarity doesn`t always cause a 'fry up' ( :D ) as many electronic gizmos have internal short circuit protection,but they don`t all have this,so do the checks first.
And RTFM as regards installation requirements.
Hope some ....or all ...of that is of some use.
P.S. It`s normally good from the Forum Etiquette point of view to say hello and introduce yourself in the Newbie Forum before asking the questions
