I found a cheap rear mudguard £12.
vanandy
Ryde, IOW, United Kingdom
OK, it needs work, going to cut the back end up a bit, put some kinda 45 degree angle rear light, jobs a goodun.... maybe.:beer:
Obviously I need some tube bent and welded....in progress.
NO WAY !!! YOU CANT DO THAT :blast :eek:yes:jes
what look are you going for? it looks like it should be on a vrod or something with a 240 rear tyre :hide
acerbis ?
you do know there was a clause in buying my bike, that it must be improved not made to look even more like a tractor :D
what else have you done :eek
You're responsible for this peepingtom :nono
We'll have to send the boys in now to sort this mess out.
Not a lot, managed to rattle can the tank white yesterday, came out quite good, yes its too cold but I had the cans in hot water and had an electric paint stripper trying to warm the place, 12.5 degrees. Can a shop clear coat rattle can paint? need it petrol proof.
Got a DRZ 400 front light / cowl on its way, XR125 clocks to fit.
Won't be long till i'll be out playing, hopefully.
I was thinking galvanised but I did'nt like the idea of the noise should it go off road.
Also, GSXR1000 pipe to fit when I get a plate deliverd.
Photoshop mock up -
Photoshop mock up -
I reckon you could easily finish that off with the ironmongery from the bench seat in your photo - for genuine Heath Robinson appeal!
Hmmm, I haven't got my head around the tail rack yet, cast iron bench seat? well i never thought of using but I recon its now on the top of my list, I might have to check the scrapper. Or cut up the bench behind the bike..
DRZ400 headlight fitted
Hi
Just thought I'd show you the bike with DRZ headlight, XR125 clocks and some carbon wrap, don't look too bad.
If you look you might see a bit of alley angle, some inner tube and some zip ties.
A bit easier.
I cut the big slots with intentions of using big stainless clips, but I think I'll just get some thicker zip ties.
Don't panic about the trapped brake line, will get it extended.
looking good andy, good stuff:thumb
may be put a small tool roll or something between the bottom of headlight and mudguard ? just a thought as theres a little gap there
Yes, cheb they are
Sent from my GT-N7105 using Tapatalk
How have you shortened them? I put 75mm spacers at the bottom of the springs on mine. I'm sure there's a thread on here about it. It also only needs a couple of relatively simple spacers to use the BMW front wheel.
Similar threads
