I need a flywheel locking pin ...
Nin
Abingdon, Oxfordshire
Fellas
The SE is beginning to go back together, starting at the back and working forward - not a bad rule to follow in life.
I've got the back wheel on now, and because heads and barrels are off I really want to lock off the flywheel so I know the engine can't rotate. I gather there's a special tool out there, but Google hasn't been forthcoming.
What do you guys use?
Nin
To lock it via the wee hole under the starter motor? Anything of the right diameter should do. Try an old philips screwdriver.
