They are about £24 each , couple of places sell them online .
One of the sellers is on Team Valley industrial estate but have an E Bay site , other is called something like Led Performance .
Will see if I can find links
The image shows an aftermarket Max Inc. LED auxiliary spotlight mounted on a tubular engine/crash bar of a motorcycle using a metal bracket and rubber-lined clamp. [1]
Found this, so removed the lamps and cut the wires back to remove the crappy work. Will cover in heat shrink when I can grab a heat gun from work. Might fit some new DRLs at a later date.
Those lights can be had for about £15 a pair and make decent DRL's. I have them connected to my R1150GS and my Africa Twin via the handlebar controlled switch (there are a couple of Sumitomo HX 060 female connectors on the Honda wiring loom to take LED AUX lights.) . I connected mine with supaseal connectors and have a couple of spare lamps which I haven't needed to be honest. They have been on the AT for about 36,000 miles.
