Greyscout
Ever wondered what goes on inside the idle control valve ....... read on ! Before you panic - this was one was U/S which is why it was dissected ! Rather disappointing because on the outside they looked really clean - but more on that later.
Starting from the right we have a permanent magnet with an internal threaded insert. The next item to the left has two coils or field windings, one to make the magnet spin one way, the other reverses the magnet. You will see that the plunger on the far left is also threaded, so when the magnet spins, it causes the plunger to move into or out of the spinning magnet.
There is a small bearing at the top of the magnet, this one was seized due to water ingress, which explains why the idle valve wasn't working !
Here you can see the two coils which create the field to make the magnet rotate.
In this picture you can just make out the 4 very fine wires (two for each coil) which would connect to the plug on top of the idle controller.
