If you can't get the top box of your 1200RT open
Myke Rocks
Newry, Co. Down
When you kick the life out of it and it eventually opens, do not dismantle the entire top box from inside.
On the outside, under the handle there are 2 torx screws and 2 8mm nuts. Remove.
Take Off Handle.You will now have the problem in your hand. a 5mm diameter pin has fallen out of the handle and is now missing, so the toothed quadrant which is supposed to open the catches only moves 50% of what it should.
Hard to spot.
Get a 5mm x 30mm cap head Allen screw and self locking nut and replace the missing pin with this. That's it.
Myke
I had that problem. Lived with it till I changed bike. If I ever bought another rt I'd have a Givi e55 instead. Helpful post though. JJH
Does that 5mm pin have a circlip at each end?
I had a small bar drop out when I opened the box yesterday,couldn't for the life of me see where it came from.
The top ox still operates ok,
If you have a pic of your mod,that would be fantastic.
Box lock
Thanks for posting this Myke,now sorted.
I didn't need to remove the handle,just turned the box upside down to get at it.
I used a 40mm long bolt as there is plenty of space and I was to lazy to cut it shorter.
I compared my box alongside another to see where the bar had fallen out from.
Pic attached I hope to show new bolt replacing the bar with fiddling little circlips.
The lid opens and locks a treat now:thumb
A bit tardy, but:
I had the box off and already removed the lid for repainting when I started looking for the catch problem.
You are correct, there is no need to remove the lock. You are lazy though.
I took a 40mm stainless Allen Screw and cut it to 30mm. This meant that the catch not bearing on threads. For some reason, photos will not attach tonight, though I have done it often enough before.
Myke
