Borderbob
Hi Bob, good to hear from you - is that the lovely black PD you had in the garage?
For lights I'd run a fused live from the battery via a switched relay using the pilot light feed as the switching circuit. That way all the load is going through a dedicated loom just for the lights.
Sent from my SM-T395 using Tapatalk
Yep it is the very same. Its a superb example in fantastic condition and not been messed about with - hence my reluctance to do so other than attach things that can easily be taken off again. Yes I'm getting the load via a relay directly from the battery. Agree, it's a good thing to have a separate loom. When you say the pilot light, do you mean the light on the dash showing the ignition is on? I'll have a look at going in there again. Seem to recall its not that easy on a PD and requires a bit of dismantling. But hey. I've got time these days
