JohnC
For about a week or so now I've been experiencing what must be an ignition switch problem. I did a quick search and most ignition problems seem to be EWS related. I'm not getting any EWS warnings. The symptoms are, when I first switch on the ignition in the morning 'nothing', blank display no lights, although I'm sure I once seen a brief attempt at the lights coming on. Switch off, on, nothing. Repeat a few times, nothing. Leave for a minute or so and then it works OK. The bike is always on the centre stand with the side stand up.
It's sporadic but seems to occur whenever the bike has been sitting for a while, i.e overnight or when its been sitting all day at work. It does seem that it's now becoming an everyday occurance though.
The ignition works fine once it's up and running and I can stop and start as much as I like after the initial failure.
The bike is due a service next week and I'm hoping it will last till then. I havent tried my spare key yet so I'll give this a go tommorow and I'll phone MC and tell them the symptoms. Anyone else had a similar fault?
I'm guessing the ignition barrell (EWS ring?) is no longer for this earth.
The ignition works fine once it's up and running and I can stop and start as much as I like after the initial failure.The bike is due a service next week and I'm hoping it will last till then. I havent tried my spare key yet so I'll give this a go tommorow and I'll phone MC and tell them the symptoms. Anyone else had a similar fault?
