Indicators staying lite after ignition off
philipgordon
Newcastle
GSA 1250 2022
I have an itermitant fault. When turning ignition off sometimes the indicators (running lights, normally on when ignition on) stay on. Its not the parking light feature as indicator switch wasnt activated when switching ignition off. Spoke to BMW UK they suggest contamination of indicator switch.
A. has anyone else had this issue?
B. is accessing the ignition switch for cleaning relatively easy, I'm new to GSA
Is it under warranty?
If so give it to the dealer to sort
If not new switch cluster time
With the ignition turned off.
If you disconnect the battery for 30 seconds when the indicators are on.
Then reconnect.
Do the indicators come back on?
