dai12gsse
Hi all,
You recently helped me with some info on making up the CAN BUS lead for my zumo 660......which worked a treat i might add
I have mounted the unit using a migsel mount (quality bit of kit!!) and the ram mounts and cradle supplied with the kit.
When i attach the unit to the cradle (ignition off) nothing happens
when i turn on the ignition the unit comes to life.....so far so good
When i turn the ignition off the garmin stays on indefinately....shouldn't it turn itself off after 30 seconds or so?
when i remove it from the cradle (after several minutes of it being in the cradle and on despite the ignition being off) it tells me that i have disconected it from the vehicle power source and that it will shut down in 30 seconds unless instructed otherwise.
If i then turn it off and re-attach to the cradle (ignition still off) then nothing happens (which is as you'd expect)
My question is:-
Is this normal? Shouldn't power be turned off after 30 seconds or so of ignition being turned off thus switching off the unit (which i thought was the whole point of the can bus lead) or do you have to physically turn it off every time, even after turning off the ignition?
Its a minor irritation to be honest but i'd appreciate any advice you may have.....
Thanks!
My question is:-
Thanks!
I hope i can return the favour some time (not that i wish misfortune on you in the first place of course
