Has anyone got a copy of the fitting instructions for this hugger...I believe that it is the same as the wunderlich one.
In particular, is there a spacer type washer and if so, where does it go?
Also, what are the recommended torque settings for the caliper and torque arm bolts with the hugger fitted?
I appreciate that it appears simple, but I have noticed that I am getting an increase in brake dust on the rear wheel and the rear brake disc is getting hot (appears to be rubbing for no particular reason)......I just want to make certain that the dealers have fitted it correctly!
Regards
Regards
