I'm thinking of buying a 1390 superadventure R.......
Mad Hatter
Ain, 01, France
I am seriously thinking of ordering a 1390 superadventure R when then come out in a couple of months. Anyone else here thinking of gettting one? Should probably go to a KTM forum for this topic, but I like this forum😁
If you know your stuff on KTMs, then why not. The R is more off road biased than the S, so if you do a lot of off road then probably a good choice. It has manual suspension and no Active Cruise Control, which suits some people, and a 21inch front wheel and 18inch rear rather than the more common 19/17 on the S.
I prefer the road biased version, I have a 1290 SAS and I am waiting to test a 1390 Super Adventure S Evo. I was told each UK KTM dealer will get one around the end of October, but will believe it when I see it. More likely to be early next year from the press are saying.
You could always wait 6 mths, when KTM will no doubt be knocking 25% off and screwing existing owners resales in the process. (as always seemed to happen annually)
Why not?
Because the build quality, probability of problems and level of service (all parts of service) after ‘serious’ engine failure is below acceptable. Other issues which have meant lost riding days and even problems with their branded accessories. This is personal experience with a new bike.
Mate also had a 1290 (dont think the 1390 should be better..) which he successfully rejected. Engine failure again... KTMs answer for the dealer to sort out, as parts were out of stock, remove the parts from another bike that they held in stock and KTM would…sort something out!
Dealer and KTM politely told ‘no thanks’.
You have been warned.
Edit.
To add, without going too far in depth, I had half an engine replaced, after a long wait. Is that what you want? Or.., a new engine? This after dropping a valve, damaging piston, head etc.? Then hope that there has been no bottom end damage due to fragments of metal or debris partly blocking an oil-way (now or later..)
Find something in the BMW or Ducati range would be my recommendation. Even 1 year old, three years ‘useful’ warranty would remain on approved used. Yes, issues can and do occur. But you should not end up stuck with a bike worth pennies that is nearly impossible to get rid of without taking a huge financial hit.
KTM are continuing to mess people about with warranty work, dont believe the bullshit from journalists who should really have our interests at heart, and not the next freeby coming their way.
