blagonadezdins Registered user Joined May 31, 2010 Messages 82 Reaction score 0 Location Bristol Oct 20, 2010 #1 Does anybody know an independent BMW mechanic in Bristol?
chad Registered user Joined Jun 28, 2006 Messages 11,370 Reaction score 17 Location wickford essex Oct 20, 2010 #2 closest i know of to you is Cardif motorrad ,,,very very good http://www.cardiffmotorrad.com/
blagonadezdins Registered user Joined May 31, 2010 Messages 82 Reaction score 0 Location Bristol Oct 20, 2010 #3 chad said: closest i know of to you is Cardif motorrad ,,,very very good http://www.cardiffmotorrad.com/ Click to expand... Thanks Are they cheaper than Bristol mottorad?
chad Registered user Joined Jun 28, 2006 Messages 11,370 Reaction score 17 Location wickford essex Oct 20, 2010 #4 i couldnt say but phone mike up and have a chat very helpfull guy and he is an independent he re-built a mates 1200 FD not so long ago at a reasonable rate and is well thought of
blagonadezdins Registered user Joined May 31, 2010 Messages 82 Reaction score 0 Location Bristol Oct 20, 2010 #5 I also have problem with final drive.... Wheel free play,horizontal and vertical with rear break on and off Any suggestions?
chad Registered user Joined Jun 28, 2006 Messages 11,370 Reaction score 17 Location wickford essex Oct 20, 2010 #6 is the play on the definitely on the wheel as sometimes you have play on the pivot bearings where the FD mounts to the swing arm "paralever" bearings some reading http://www.ukgser.com/forums/showthread.php?t=226282&highlight=check+final+drive+bearing http://www.ukgser.com/forums/showthread.php?t=192853&highlight=check+final+drive+bearing if your still worried about the bearing pop the main seal out and haver a butchers at it http://www.ukgser.com/forums/showthread.php?t=159180
blagonadezdins Registered user Joined May 31, 2010 Messages 82 Reaction score 0 Location Bristol Oct 20, 2010 #7 chad said: is the play on the definitely on the wheel as sometimes you have play on the pivot bearings where the FD mounts to the swing arm "paralever" bearings some reading http://www.ukgser.com/forums/showthread.php?t=226282&highlight=check+final+drive+bearing http://www.ukgser.com/forums/showthread.php?t=192853&highlight=check+final+drive+bearing if your still worried about the bearing pop the main seal out and haver a butchers at it http://www.ukgser.com/forums/showthread.php?t=159180 Click to expand... Thanks a lot Chad
chad Registered user Joined Jun 28, 2006 Messages 11,370 Reaction score 17 Location wickford essex Oct 20, 2010 #8 blagonadezdins said: Thanks a lot Chad Click to expand... no problem
MikeS Bloke UKGSer Subscriber Joined Aug 3, 2010 Messages 2,490 Reaction score 731 Location South West Oct 20, 2010 #9 I live in Bristol and my bike is at Cardiff Mottorad at the moment, very good.
