Indicator micro switch’s
garry a
sandridge st albans england
Hi I’ve just had to use my last spare micro switch to repair left hand switch gear has anybody found a supplier for them yet. Seems mad to me to have to replace hole thing for the sake of a 50p micro switch.
Should have checked your link Groceryrun...same thing but only cheaper :D
Can you upload a photo of the actual switch and where , on the motorcycle , they are used ?
Is it round like this -
http://uk.farnell.com/c-k-components/k12c12-5n/switch-1mm-travel-2-5n-ip67-seal/dp/1908196
Left Hand Indicator Switch not working.
I am delighted to find this part number, next thing is to figure out what size Soldering Iron I should buy. Any advice would be appreciated. I was going to order one on the Farnel website at the same time as ordering the micro switch.
What is the best way to cut away the epoxy (or whatever is sealing the terminals and cable) before soldering the new switch terminals? Any ideas as to how best to seal it before remounting the switch gear?
