Indicator switch problem.
notagser
South Queensferry
My RH indicator switch feels less "clicky" than the LH one, and the self cancelling function doesn't seem to work on that side. (Ok when indicating left)
Does the symptom suggest a gunged up switch which could be cleaned out, or is it heading for terminal failure?
Have a go at it with some wd40, or you can remove just the front of the switch from the bar, and get to the back of the switch.
Same problem on my 11GS last month. One squirt of WD and it's been fine ever since. Opened the cluster and soaked it then after refitting , all was well.
