injector covers,no instructions
fizzer
co durham,england
anyone know how these covers fit on ,for the life of me i cant work it out ,they are supposed to fit all lc models 1200 and 1250
Have them on mine - and yes it does take a little bit of working out. Bit late to toddle into the mancave tonight, but I'll try to do some pictures in the morning
Attached are pictures of them attached to my R1250GS - Nearside, Offside and fittings underneath - if you look at the last picture, you will see how the brackets fit - hope they are clear enough for you to make out how it all bolts together. When you come to put the covers themselves on, you may have to "spring" the surrounding bodywork a little to get them to go under, but once in place, all returns to normal. Also note when you bolt the bracket onto the injector to have the nut at the bottom, else if you put it the other way up, it gets in the way of the screw when you fit the cover
cheers for that fella ,taking the time to take it off and show me the fixing,very good of you.
yes it all makes sence now .thanks again
