Innovv K2 Camera
Sharik
Salisbury
Has anyone fitted the Innovv K2 camera system to their F700 or F750, if yes, where did you mount the front camera?
Many thanks.
Fitted the INNOVV K2 to my F8 GS, placed front camera on beak, works well , no distortion
Thank you Thomo. The 700 does not have that 'V' cut in the beak, quite the opposite, it has a slightly raised middle section. The camera would be very obvious and more prone to theft or criminal damage if mounted in the same position.
My mate has the camera system on his GS. It has been fitted just above the o/s indicator using the bracket and fastened using the same bolt which holds on the indicator stalk.....looks brilliant
