Innovv k2 connecting via PDM60
Gordyman
ESSEX ENGLAND
Hi All
I have installed a PDM60 and now my next job is fitting my Innovv K2. The K2 requires two supplies one a permanent live and another switched live. Am I right in thinking that I can achieve both of these by utilising two of the PDM60 circuits provided that I set up the circuit program correctly ie one circuit direct live and the other ignition triggered?
Yes. Whichever wire you choose from the PDM60 can be set to 'always live' or whatever they call it on the drop down menu.
Because the PDM60 is wired directly to the battery, presumably this option gives you a direct line to the battery. However, is that a good idea? I think it is possible to also choose an option that means with ignition on, the chosen wire is instantly on - no delay. Maybe this is better?
If you have the PDM60 alredy set to disable circuits on ignition off why complicate things just use that feature?
