Innovv N3 or Carpuride W702BS
Spook1969
Northampton
Probably been asked a hundred times but I can’t find it on a search.
I have a 2017 GS with Analogue clocks and am looking for a CarPlay unit to work with my iPhone.
Has anyone used the Carpuride and the Innovv and have any opinions. From the visual aspect the Innovv looks to be a higher quality item but I’m not disappointed with the Carpuride. I won’t be swapping from one bike to another with this it will just sit in the Nav 6 holder and I’ll use the wonder wheel.
Are they both similar in function?
I'll through you a curve ball and recommend you what to me is the best option, which is the RiderNav R7M
I do have a playlist if you want to compare it to others like the Innovv or Carpuride.
Hope that helps!
Thank you, I'll have another look through that and also compare the overall sizes. Friend had an Innovv N2 last month and it looked about the right size and it was faultless over the two weeks. Only monor issues were MRA and that will happen with most of these Carplay units.
What is the issue with MRA on the CarPlay units? There is also Chigee but expensive
No issue with MRA and CarPlay. Sometimes MRA has a glitch which mirrors on the CarPlay, 99% of the time it’s seamless. Two 5 min hiccups in 14 days is acceptable.
Im on a Ridernav R7M, was on a Carpuride 702 - previous version with no jog wheel integration. Finding Ridernav more stable, not perfect but very good.
