Inserting waypoints into a route MRA app or website
Berin
South Oxfordshire
I’m trying to create a route on my phone, and I want to modify the route the webplanner has chosen.
In the web planner I can add a waypoint/via point but it always adds it and the end, so I have to go in and reorder the waypoints.
Is there a way to insert the waypoint so it’s in the right order?
Just been modyfying a route in the route planner and adding waypoints. Not sure if I understand your issue. But if you want a shaping point or waypoint between two existing points, if you hover over the route, the curser changes to a plus, you then move that to the location you want and the point then gets inserted between the two points.
If you just click on the map or enter search, the point goes to the end of the list and you then have to drag it to the point in the list where you want it. Sorry if I have misunderstood what you are trying to do.
on a phone?
I can’t see a way to open a route in route planner on an iphone- just to create a new one
Found it, thanks for the pointer. Open the route from routes and tracks, then click the pencil, then the options to modify appear including a sort of “hover” with your finger
Another question!
Is there a way to insert a poi into the route.
On this section below I want to insert the poi between 9 and 10.
Yes,
Click on the cross
IT comes up as the last waypoint so you have to adjust the order.
