installing Oil Cooler guard
Hubs
Totnes, Devon
Hi, just received an excellent oil cooler guard; now trying to work installation process. Is this a beak off job (and if so how) or a lights off job, or some other variation - any hints willingly accepted!
thanks
Mark
Hi, its a rugged roads part, for an 1150GSA. Any guidance on how to drop teh beak?
Ta
Mark
Hi, did a better search and found a bunch of suggestions - thanks!
Mark
Being a tight git i made my oil cooler guard from a B&Q sheet of mesh.
I didn't drop the beak.Remove the screen,silver instrument cover and plastic light surround and you should have space to silde the grill in.
Same as me :thumb:D Cost about 15 pence.
hey Colban, just thought, are you heading to willingham woods tom at all? ifso i may head over an have a look at the mesh you fitted? sounds like a good cheap method to me.
beak off then fit to grill, easy for 1100
undo the bolts that hold ye oil cooler on ,then the self tappers on the beak.
depending on what cooler cover ye fit shape the grill so it all goes back same way.
ugg
ugg.tek modifications:D
