Intermittent headlight failure & ‘LAMPF’ warning message
Dan79
Member
Bedfordshire
Evening chaps, something very odd happened today. Whilst riding this evening I noticed the headlight suddenly go out, accompanied by ‘LAMPF’ and the yellow warning triangle. Bizarrely, operating the main beam flash button 2 or 3 times seems to clear the issue and the headlight operates again. The C shaped daytime running part of the front light cluster remains illuminated throughout. It did it repeatedly at dusk, 7 or 8 times, then when it got properly dark I rode for 2 hours with no problems (lights operating normally, no warning lights or messages), then at the end of my journey it started doing it again, and at this point the ABS light started flashing too. Anyone else had this or k ow what might be causing it? Cheers. Daniel
Have you got the headlamp setting on auto. Maybe a problem with the light sensor.
Thanks, yes I have. I’ll change the settings tomorrow and see if it still does it.
Could be this on my friends bike everything worked apart from lights ZFE module but I would get the codes read first. I would also disconnect battery for a while it may reset itself
