dakarjim
HELP!
decide to fit the spot lights on my Dakar today, having finally got all the bits i need (including some nifty brackets many thanks to VAL H.)
underneath the high mudguard are four torx bolts, not sure of the torx number but i think an M6 thread. did the right hand two no problems, then the first one on the left came out.
the second one undone about three quarters of a turn then went tight; so i put a bit more weight on it and the torx bit slipped, and chewed the hell out of the bolt head
(i probably should have tightened it up a bit then undone it again, 20/20 hindsight i guess
any ideas how to get it out? i've tried the next size up torx bit, no good, cant get at it with mole grips, cant heat it because of the plastic behind it, its turned what should have been an easy job into a fekking nightmare!
why do BMW use such shitey fasteners anyway?!
any help would be greatly appreciated
Jim
Jim
