Sold IOR Valdada 7 X 40 Binoculars
PIGGLET
N Yorks/Smoggville
IOR Valdada 7 x 40 military binoculars. I bought these as unused, new, old stock about 15 years ago when I was getting into deer stalking having been underwhelmed with a couple of pairs of 'budget' bins. At the time they were relatively unknown but I had heard good things about IOR via snipers hide and subsequently bought an IOR tactical scope and despite being a bit of a chunk it was noticeably optically superior to the Nightforce and Schmidt and Bender scopes I had so took a punt on these. I believe they use Schott glass (Zeiss). They now have a bit of a cult following by those who've tried them.
They are a bit on the chunky side at 1.1kg but they are beautifully made and extremely rugged. Despite the weight, being rubberised I found them comfortable to wear with a chest harness. The stand out feature is that they have twin diopter adjustment and what can only be described as auto focus so you set them up for each eye and then from about 25 meters to infinity your eyes do the focusing. They are like no other binocular I have used before in that regard and it works really well. Set and forget with crystal clear optics. Optically they will outperform anything at twice the price point but as they have been sat in a box for the last 13 years it's time to let them go.
These are the military version so have a range finding reticle (handy for ranging deer or a Russian tank ) and a drop down internal IR filer (handy for spotting the helo when you need a stealthy extraction up from the pub). They also have orange low light filters stashed in the end caps which you can clip into the eye pieces for snow/flat light or other conditions which have never been used.
£200 RM SD to your door.
20251118_124518.jpg20251118_124546.jpg20251118_124732.jpg20251118_124740.jpg20251118_125235.jpg20251118_125245.jpg20251118_125302.jpg20251118_125326.jpg
I have just this past weekend
ordered these, but will see if I can unwind that and then we should talk...
Have a shufty on t'interweb at the reviews and info before you do anything rash. They quite different to the bins you've posted a link to.
Thanks, @PIGGLET
Yes, you are right about the significant difference!
I have cancelled the order that I had anyway, as I think 8x42 is more manageable for what I really need (initially, during a coastal cruise)... And the weight of your set is, upon further consideration, a bit daunting for just having a set to hand.
GLWS and thanks again.
Thanks, @PIGGLET
10x will be a bugger to hold steady. 7 or 8x is as much as you want for hand holding. If you want a REALLY good pair look for used 8x42 Swarovski, or the rubber armoured, Zeiss 7x42 Dialyt. I have had both and for me the Zeiss are better, even though they are slightly lower power. Low light performance is far superior to the Swarvoski. If you want a light and compact pair, the Zeiss 8x30 dialyt with the tessar star coatings are sometimes on ebay. BOTH will be much more expensive than the IOR here.
Thanks, Ratty... I appreciate your words but in the interim, fell for a pair of Zeiss Terra 10x42 in an un-opened box on eBay for the appealing sum of US$275. I wish that I could have afforded my original target of used 8x42 Leica BN... But a fiscal reality check took precedence.
You're right: 8x42 would have been a better option in terms of image stability.
Lesson: "Less is More".
I appreciate you taking the time to post.
