iPhone/iPod dock extension cable...
Micky
Never knowingly understood
South Yorkshire
The iPhone won't sit in the dock with its case on, nearly everyone has a case of some sorts on they're iPhone :nenau
Now I would have thought you would be able to get an 'extension' cable to plug in to the iPhone/iPod docking station, plug in to your iPhone or iPod and use as if the phone was sat in the dock .... but no!
You can get a charging/data extension cable but your iPod or 'phone won't play the music etc through the docking station :blast
Tried the Apple store, no they don't do one, but hey ... what a good idea :banghead:
Anyone know of anything :duno
Jet2 do some product that's may be of use.
I use one on the gs to receive remote commands whilst riding.
Just a small block allowing a dock connector in the bottom and the same out the top.
http://www.7dayshop.com/catalog/product_info.php?&products_id=110161
This USB Cradle will allow you to more easily connect your iPod, iPhone or even your iPad with your computer. It can be left connected to your computer's USB port and the cradle can be left on your desk whenever you want to connect your Apple device. You do not need to worry about removing your case either as it has been designed to still connect your device without any case getting in the way.
- Input Power: from PC USB Port
- USB Data Hotsync
- Power Protection Circuit included
- LED Power Indicator
- Can still connect to your device without the need of removing your case
- Removeable back rest for securing your iPod or iPhone in and when removed you can secure in your iPad
- Please Note: This cradle will charge all versions of the iPhone and iPod (except the iPod Shuffle), however the iPad cannot be charged as a standard USB port does not produce enough power to charge the device, it can still be used to sync with your computer.
Compatible with:
iPod Classic (1st-6th Generation)
iPod Nano (1st-6th Generation)
iPod Touch (1st-4th Generation)
iPhone 3G / 3GS / 4
iPad (Sync Only)
Doesn't work with an iPhone 4 with Apple Bumper. However I filed down the bottom of my Apple Bumper by quite a few mm and it now works fine. Works fine with iPod Touch with silicon case fitted and with an iPad with no case.
Found out it doesn't work with the Cygnett Workmate case on :eek:
I ordered that Mike, great piece of kit :thumb
Very quick delivery, superb quality, does exactly what I wanted ... result :thumb
Where would we be without t'Internet, ehh....? :)
Glad it works for you, Mick.
