USB-C cable or extension cable with waterproof cap ?
Arsey
Guernsey or Plessala
My bike has a USB-C socket hidden behind the right fairing panel .
The idea is to plug in a cable and then replace the panel, routing the cable through the slot on the left side.
As I won’t be using my phone much with the bike I’d ideally like a 30cm extension cable with a waterproof cap which I can cable tie neatly to the centre stay of the fairing and then when needed simply plug in another 30cm cable from this extender to my phone.
But I can’t find anything .
The nearest is this
But I don’t want the bulk of the threaded bit.Just a female USB -C with a cap on it .
I’ve searched online but have drawn a blank .
Ta muchly
You could get a normal extension type cable and simply enclose the end with a makeshift waterproof box/cap.
Alternatively, there are options for caps to cover the end using 3d printers (if you know someone) or can buy some;
USB C Cap options
The nearest is this
Ta muchly
What about something like this for the female end of a standard usb-c cable?
USB C Cap options
Thanks.
I think the cap option may be the easiest ….
I’ve ordered this
Should be fine . Ta for thoughts
