Is it possible to weld this??
Slime Bomb
Stoke on Trent
Bike was leaning a bit more than normal so looked at the side stand and noticed it had cracked :eek: Is it possible to weld and if so, what type of welding, or would I be better off sourcing a good used one? Any thoughts gratefully received.
I just bought a new sideside for my 'Berg on Saturday. It wasn't worth the faff of trying to fix the old one.
Greg
You can pop over and have a go at welding it if you want,but you get to take it off and put it on again:thumb2
Greg
It's better to fix the Berg one's rather than buy new, that way they can be made stronger at the same time:thumb
Funny, I was just gonna post the same - mine went just below the pivot point (it seems a common thing on Bergs :nenau) so I welded a sleeve around that point in order to beef it up.
Andres
I've welded a kick start on an XT550, with the same sort of split , though mine was in two pieces, and it held fine.
I just set the MIG welder to its highest setting and laid a bead on the exterior face.
I then ground it down for neatness, and so it would twist back in towards the bike.
It really depends on the cost of the new stand.
tbh, I did buy a replacement kick start too, as did not want to be stuck in the @rse end of nowhere trying to bump a muddy 550.
Replace
It's possible to weld that sidestand properly - but only if it's prepped properly by vee-ing out crack with a angle grinder etc, but that crack also ends in the thread for the sidestand pivot screw (metric fine I think) which would need re-tapped and is already a bit of a weak spot with the sidestand design & the hole for the switch would also need re-drilled.
So, on this occasion I would vote for picking up another sidestand (ebay?) - easier & safer.
Cheers.............................Grizzly:beerjug:
There'e plenty on ebay Germany. If you contact the seller and offer to arrange a courier, you'll usually get a sale. Some chaps even post over here without hesitation, you just have to ask.
Well Spotted
Well spotted Madmountainman - plenty of choice including one in the Netherlands with a "bigfoot" pad attached - there you go Slime bomb - sorted:thumb.
Cheers.....................Grizzly:beerjug:
Motorworks want £117.00 for a new one!!! None on ebay neither. Thanks for the offer Vern, I'll keep it in mind.
I've got one, good condition , no cracks...the light is reflecting oddly on the base in this crap pic, but it's not rusty
£30 + post at cost?
Result! And thanks to you all once again. Being a member of this site is the best few quid I've ever spent! :clap:beerjug:
