Is it Possible to
digga
Coalville
remove the 'box' that the fuses/ relays sit in??
I want to be able to get in under the relay holders to fix a fitting!
Had a quick look last night in a dim garage ..... it did'nt look too good, anybody any experience???:nenau
If its like the 1150...
I've lifted the top half of the box (4 hidden x-head screws i believe) while looking for a short.
You are limited by the cable loom going to the relays/fuses.
Its a bit like Vanessa Feltzes underwear;you dont want to be going in there unless you REALLY have to.:eek
piece of the proverbial mate. Follow that guideline. Its not as scary as it seems :)
i used a heat gun to warm it up a bit... but yours is all cosseted in a nice warm garage so itll probably be quite flexible enough :augie
Yes, but thats what sorts out the (mad?) men from the boys!!!.
dave gs (not that mad!).
Have a look at the first part of this mate ......
http://www.ukgser.com/forums/showthread.php?t=34417
That what you after?
Top tip, made it a lot less daunting..
I an considering fitting another auxillary socket into the void beneath the fuses...nicely out of harms way, easy to get to (to use!) other than that it'll be on a plate 'P' clipped to the pillion foot support loop.
Thanks for the help chaps..
