Given your location, I assume it's a 20,000 km service?
Engine oil and filter change.
Gearbox oil (if it's two years since last change).
FD oil (if two years since last change).
Air filter.
Check/inspect brakes (replace pads if required).
Change brake fluid (if annual service).
Change clutch fluid (if bi-annual service).
Change plugs.
Check rear wheel bearings, swing arm bearings, check/adjust throttle cable free movement and condition.
TB sync.
There is a manual out there somewhere in PDF format.
