Kx 125 help please.
JJH
Co. Meath Irish Rep.
Friend has bought a kx 125 1989. Got a few hours out of it and stopped. No spark then there is one then there isn’t. Disconnected cutout switch. Still the same. Took of side cover and flywheel to find a mess of chewed screws insulation tape and even duck tape and messy solder. Quick google suggests there’s problems in this area. eBay seems to be full of replacement stators both new and second hand. Does anyone know what I need to buy? It’s fairly obvious where the problem is but do I buy a whole new assembly for about €100+shipping? Does anyone have first hand experience on this? What’s comparable will any one do? JJH
Where do you want someone to start?
from what you describe, its a mess, and the fix could be £5 or £500
Start with the basics
Have you got a working spark plug £5
Is the spark plug cap ok £5
Is the plug lead ok £5 ( if replaceable)
Is the battery full charged? holding charge £40
Is the coil ok? £40
Is the stator ring ok £100
Cdi unit dead £100
Any one of those will potentially give a non spark to a plug
Are you getting a trigger voltage from the stator ring? to the coil?
if one of the coils on the stator ring goes , that will kill any spark / trigger form being generated
Personlly id chop out all the old bodged stuff, get a manual or wiring diagram for it and start again.
new wires to all the components that are in the bodge path
then see how you get on
Wow that’s unusual. Nobody has even an opinion. JJH
I have an opinion, but perhaps not really worth sharing..
I would be looking for the test values from a workshop manual - it might be the Stator, or Rotor, or the plug cap, etc
Go on, show us a picci :nenau
Doh! slow typing hands means my opinion is worth even less!
Steer clear of 'friend' until he's got it sorted :augie
Wot Santa says.. Rip out all the snot. I've just rewired the Stator on an 88 Vespa, insulation cracked & broken off in chunks use the same gauge/thickness wire. Hopefully that'll sort it :thumb2
That’s the best advice I’ve received so far. I was really hoping that someone would know exactly what’s up and know where to get the new parts that would be twice as good ect ect. It’s a sorry sight in there. He only bought the bike last week. I advised him to stay from Chineese shit. Didn’t expect this heap to be disgorged from the back of his van. JJH
