I've 3D printed quadlock for Aoocci C3 and others?
Pete, Andrewb2006 is my test pilot for the C6 Pro - as soon as he confirms that it fits then they will be available.
Andrewb2006 . . . any news on the C6 Pro bracket, unit arrives Saturday and I'll be itching to install ;)
Afternoon All,
The C6 pro has landed
The Quad lock bracket is a perfect fit twisting easily onto the quad lock mirror mount
I have also test ridden 60 miles with no issues or vibrations so all good get ordering everyone!!!
I enclose pics fyi
Many thanks
Andrew
Thanks for the comprehensive review Andrew!
These are now listed on eBay - search for 'Aoocci C6 Pro Quadlock' and you'll find the listing.
Afternoon All,
I enclose pics fyi
Many thanks
Andrew
Nice one Andrew . . mine arrived today too, a day earlier than stated :)
Hi all. Whilst the C3 is all I need, I want it to be easily removable for when the bike is not in either the garage or the works basement car park. Power is easy if you use a USB power socket near the device but the mount is a different story.
I use quad lock all over the place so 'borrowed with pride', i.e. blantantly copied a 3D print quadlock female socket and added it to a base plate with hole spacing to match the C3 mounting plate. Looking at the other Aoocci units, it might fit the C5 and C6 models as well
Does anyone else use quadlock and want one? I can bash a few more out if needed. The hole spacing on the mount is a slightly odd 61mm x 29mm so if you have a C5 or C6 it would be worth checking.
Hi is it possible to order a C3, couldn't find them on eBay Thanks
They are called ‘Aoocci C3 Quadlock Adapter 3D Printed Quick Release UKGSer’ on eBay - I’m not permitted to post a direct link to the auction from here.
Hi. Just received my C6 pro. Wonder I could order the female quad lock mount for it from you if possible. Will cover your time also. Great idea.
Murdo - they are listed on eBay - search for ‘Quadlock Adapter 3D Printed Quick Release UKGSer’ and you’ll find the C6 model
Has anyone added a quick-release mount base to the Aoocci C3? I'm wondering if it's necessary to get one, or if the standard setup is good enough.
Just to say I'm using 2 of dp66's 3D printed quadlock adaptors for some months. I had one supporting my C3, as I rode 3.5k miles in June to Romania, Bosnia and Croatia. The adaptor supported the unit faultless. If I was unsure about where I parked the bike, I could pop the unit off with the quadlock release. This is a good solution. Thanks dp66!
Sent from my SM-G991B using Tapatalk
Do you have this 3d print file somewhere you could send it or share it?
I have also recently purchased an Aoocci C3 for car play apps and shorter or just A to B navigation. (But still using Tom Tom For extended routes) So looking at these 3D printed adapters for the Quad lock system, all looks good, however, should there not be a gap between the back of the device and the adapter as all official phots show a gap using rubber bungs. Has anyone fitted the 3D adapter plate straight onto the back of the device? if so any issues or did you somehow insert the rubber bungs supplied with the fitting plate into the 3D adapter plate screw holes? Hope that makes sense.
