Maybe a stupid question but if the needle's in the the carb's get worn need replacing do the jets also get worn and need replacing after a while? I'm trying to get to the bottom of rough running on my bike. The carbs have had a good clean and have new needle's. It was quite rough around 2500-3000 so I balanced them and sorted the idle which helped a lot at the lower rev's but now theres more vibrations through the pegs and bars at higher revs, 4000+. So my thoughts went to the main jet's and if its possible they could be worn.
Not sure what to try next.
