Delboy777
Is it worth fitting one ?
Apparently, NO.
It WILL make the engine run dangerously lean, so a remap or Powercommander etc will be required afterwards.
Nope, waste of money
Apparently, NO.
I put a pipercross in mine when I bought it in 2008, as it never needs replacing just a clean I would say it is worth it financially as it has saved me from having the standard filter replaced in the last 6 services,
service interval for air filter is 24k, you would need to do a lot of miles to make it pay for itself.Apparently, NO.
Id like to do a Hilltop remap but feck me its hundreds of miles from me ! Might do it in the summer when im on holiday, be a nice little ride down into deepest Englandshire lol
Until it needs replacing....... Buy a BMW one or clean and reuse a K and N again, and again, and again and........
There you go, advice listened too and will be followed, OEM it is. Thanks guysFactor in the initial higher cost of the K&N, factor in the cost of cleaning liquid, factor in the cost of the filter oil.
Factor in the time spent cleaning and re-oiling the filter and cleaning up yourself.
For well over 100K miles the original works out cheaper, but the main factor is the better filtration offered by the original or aftermarket paper filter..
Yeh i know Chap, ive been up to him in the past with a 1250 Bandit, it was a pig and he sorted it out.Delboy, I believe I have met you (although you were broke down at the road side at the time) therefore I know the area you live (you told me) and there is a good motorcycle dyno place on your doorstep 1.5hrs max from you. They will fit a power commander and remap your bike for similar money to Hillside or any combination of tuning you want up to a full blown race prepared engine, so why go south?
www.hmdtuning.co.uk
