K1200RS ABS2 fault
Buckingham
North Oxfordshire
So my new to me K1200RS has an ABS fault that I was unaware of when I bought it - discovered by a GS911 scan. Both ABS warning light bulbs were missing.
The fault code is for the front wheel sensor, but having swapped front & rear at the plugs, the rear stays free of fault codes but the front still shows faulty. The resistance of both front and rear ABS sensors is identical - 130 ohms.
I've done the pin 21 reset (someone has definitely been here before, as pin 21 has been extended from the ABS ECU plug) the reset works but ignition off and on again & the front sensor fault is back.
I've measured voltages at both front and rear sensor connectors and they are identical.
Any ideas before I condemn the ABS controller ?
TIA
John
I suspect you will find an issue on the ABS control board OR has someone swapped the ABS unit already and it is not the correct type
IF I recall correctly K and R series ABS units have some differences internally and can't be swapped Our friend Mr Maniak in France finally listened to what he was being asked and it turned out all his issues were because of an incorrect ABS unit
I successfully used an R series ABS module on a K series but I had to swap over the electronic controller from the failed K series ABS onto the replacement R series one and all worked OK
I assume you have checked the wiring harness going to the front sensor just in case you have a break ?
Yup that's what I meant. The main electro hydraulic mechanicals are the same but the Electronic control bits won't swap over
OK, so I've bought a used K1200RS ABS2 hydro unit from a breaker with 6 months warranty. It seems to have
fixed the original issue as I have been able to clear the fault code for the front ABS sensor. However, I now have
a different fault code - plunger fault code 13.
I can't seen to use any of the test functions on the GS911; I can only read and delete the fault codes. No option I can see to actuate the ABS pump via GS911.
I'm assuming this is because the K1200RS (1999 model) is not CANBUS ? Have I got that right ?
TIA
John
Yes John, I checked the resistance of the front wheel sensor right the way back to the connector on the ABS module.
More a case of the diagnostics were still being developed
and bilateral connection was not a thing
It was just read a code and clear a fault
TIA
John
I've had success removing the plungers and cleaning and re-installing them as they stick if there is any corrosion on them . Only issue it will invalidate your 6 month warranty so you might be better jusr sending it back for a replacement . As Jay has said there is no option on these older K bikes to activate the pump via a gs-911
Thanks John, it's working now. Not sure ref the plunger fault but I did a manual reset (pin 21) held it on for 8 secs & all working again.
I did read that the old type USB GS911 sometimes does not reset the ABS fault codes properly.
So since buying the bike last months, I've fitted 2 bulbs in the ABS warning lamp, fitted a used ABS warning light relay (blue relay)
and the used hydro unit from James Sherlock & that's fixed it.
Thanks to Jay and you for the help.
John
I'm attempting to remove the plungers and clean them, however I've tried 3 different 22mm sockets including a thin-walled deep socket and none can reach the top of the cover to get to the plunger. Can you tell me what kind of socket you used to get the unit open? I was able to use an open end spanner to at least reach the top of the cover but there isn't enough torque on that to get it to move.
I used a deep thin wall socket but had turned down the wall diameter so it fitted inside the casting of the ABS unit and also faced off the end of the socket so it was flat to get a good purchase on the hex plunger
This might help if you have not already seen it :
Thank you! I do have the PDF. My next step was going to be turning down my socket, I'm glad to see I was on the right path.
Thanks again!
Thanks again! I ground the bevel off my deep 22mm and thinned the outer edge just a bit and was able to get the unit open. There was definitely crud in there from when the rear brake line was failing before I changed to stainless lines. When I put it back together and reset the ABS the plunger came right back trying to do the roll away check, however I reset the unit again and then it seems to have cleared. I’ve ridden 4 times since and ABS I is working and there are no more codes.
