Kane digital manometer
ELIMINATOR
Hampshire.
Whoopee.
Quality department has just bought on of these. I was asked to put it on the instrument register. Looked at it, thought to myself........... read the instructions. Has two plugs for tubes, works on both pressure & suction, gives a differential reading between two inputs.
BINGO, can't wait to have a play for proper when the next service is due. Might even persuade myself to play with it anyway.
Anyone got one, or know if it will work?
Do you know the pressure range of the unit ?
Also I made up a differential pressure set up last year to do the TS and I found the digital set up too sensitive and was better off using my trusty length of tube filled with water and two sponge filter either end to just surpress the pulsing effect.
if you do use it remember to put some sort of filter on the inputs otherwise it'll stink of fuel.
It has a switchable damper function, so hopefully won't be too sensitive.
Can't remember what the range of the unit is...even if I saw what it was.:(
