Sold KD Benches Motorcycle Lift Table
PembsGSA
Desert
I've been considering selling this motorcycle lift for some time since it's hardly been used and is stowed in my garage.
Its not a typical internet supplied motorcycle lift similar to the Sealey models ect (the steel table types as found on the internet). Originally built by a Company based near Falkirk called KD Benches (KD Benches was a subsiduary of AL Gordon Engineering Ltd based in Falkirk Scotland), which I believe are no longer making these benches. The main load area is plywood which is very strong and will easily and securely lift any motorcycle on the market. Personally, I prefer the plywood deck work area to a cold steel plated deck.
It has a hydraulic jack built into the frame which is easy to use and a detachable loading ramp. The rear section is removable (as per photo) so that rear wheels can be removed ect.
Condition is very good with light non-commercial use . The grey carpet was kept on the table lift top surface when I was servicing my GSA (I’m fussy like that).
Photo’s are of actual lift table in my garage/workshop, and a couple of archive KD Benches photo’s which I originally downloaded upon purchase.
Very, very heavy so buyer would have to arrange collection. I'm based in Pembrokeshire SW Wales.
Quality item built in Scotland, when purchased new, I think it was over £700. I did quite a bit of research prior to purchasing and came across a classic motorcycle forum who highly rated/recommended them. There are much cheaper Chinese ones out there, but they won't be built to the quality of this motorcycle lift.
Asking price would be £450 ONO collected from SA67.
KD Benches Lift Table 1.jpgKD Benches Lift Table with carpet.jpgKD Benches Lift Table2.jpgKD Bench motorcycle.jpgCIMG0290.jpg
Reduced Asking £385 ONO collected from SA67
