Kick start?
GB.
Redneck Norfolk
Still in the process of recommissioning my newly acquired PD, but is does run very well. This bike has the kick starter fitted, I’ve had a couple of feeble attempts but is there a knack to starting these with the kicker?
It is one of the reasons I bought the bike, there is a certain pleasure/satisfaction kick starting a bike.
Also apparently there are different ignition amplifier modules for the kick start bikes to cope with the Low RPM to generate a signal If I remember correctly Proff told me that one
Yes of course ...
Standard: BMW p/n 12142325284
Kick: BMW p/n 12142325550
... but according to realoem it would seem that the part is not longer available as new part from BMW. Hearsay knows the following alternatives:
Bosch Nr. 0227 100 116
Telefunken 12.14-1244478
Also .......... https://q-tech-shop.de/en/p/hd-ignition-control-unit-transistorized-ignition-module-for-kickstarter
As Mikeyboy says, 2 or 3 steady prods.
My routine, and mine only seems to start from cold on the kicker, is:
Switch on.
Choke on full (although have been told this isn't necessary)
Half inch twist of throttle and let go
Kick 2 to 4 times smartly in one session (no gaps)
It'll either start or not.
As the Doc says.
There’s a different ignition module for bikes with a kick- start
I can’t stop humming the theme tune now. Twats.
Do you want some cheese to go with your humming ?
I find praying and swearing at it gets mine started with only 20 or 30 kicks.
