Sold Klim Badlands Pro A3 Jacket XL
Jondd21
Wales
Klim Badlands Pro A3 jacket size XL in Black / Grey
For sale due to weight loss .
Unmarked, two years old to it's brilliant jacket.
All season jacket, venting it's as cool as you can get in the heat and it's never leaked a drop when I’ve been caught in the rain.
Very limited use ( less than 10 local rides ) it. has been faultless.
It's got D30 armour and the velcro stomach/kidney belt which is a great addition.
It’s not a lightweight jacket but the kidney belt is designed to spread the weight.
perfect condition.
The only reason I'm selling it is I've lost 5 stone and it's now a little too big to be comfy.
These jackets can retail at £1500 when new.
Asking £635 posted.
Happy to answer any questions.
Spec from Klim website :
SHELL/CONSTRUCTION
  • GORE-TEX 3-LAYER PRO SHELL
  • GUARANTEED TO KEEP YOU DRY™
  • Custom-engineered variable-density Superfabric® on shoulders, elbows and forearm
  • Vectran™ Fiber Fabric for superior abrasion & cut resistance
  • 3M™ Scotchlite™ Carbon Black Reflective Material
  • Biomotion recognition
  • YKK® water-resistant zippers
  • Double-headed front zipper
  • Pending CE AAA rating certified to EN 17092-2
ARMOUR SYSTEM
  • KLIM AERO PRO D3O® CE Level 2 vented shoulder armour
  • KLIM AERO PRO D3O® CE Level 2 vented adjustable elbow armour
  • Limb- and side-specific pads for optimized coverage and stability during crash
  • D3O® Viper Pro CE Level 2 vented back pad
  • Spacer mesh back pad pocket
  • Kidney belt w/ access ports in liner to easily adjust and stow away the belt
  • Perforated XRD® Impact Protection Foam chest pads (upgradable to D3O® CE Level 1 pads, avail. separately)
VENTILATION
  • 2 Massive adjustable wrist vents w/ dual zippers
  • 4 Core vents (2 can function as pockets)
  • 2 Bicep intake vents
  • 2 Tricep exhaust vents
  • 2 Back exhaust vents
  • Collar tab back for increased airflow to upper chest
STORAGE
  • 2 Water resistant gusseted hand cargo pockets
  • Internal organizer compartments in right hand pocket
  • 1 Waterproof externally accessible napoleon pocket
  • 2 Vertical gusseted chest pockets
  • 2 Vertical core pockets (can function as vents)
  • 1 Chest utility pocket
  • 2 Lower internal zippered stash pockets
  • 1 Vertical inside chest stash pocket
  • External MOLLE-compatible chest utility panel
  • 1 Forearm emergency ID stat card / hidden stash pocket
  • 1 Concealed document pocket behind backpad
  • 1 Large dual-access gusseted back pocket
  • Internal hydration bladder compartment w/ internal hose routing options (compatible with KLIM Hydrapak 2L and 3L, avail. separately)
  • TPR pocket tabs for easier gloved access
FIT/COMFORT
  • Action-back gusseted shoulders for comfort and mobility
  • Articulated seamless underarm gussets for mobility
  • KLIMATEK™ cooling mesh full sleeve liners
  • Moisture-wicking, breathable, antimicrobial mesh torso liner
  • Soft collar liner
  • Adjustable cinch collar
  • 2 Quick-adjust bicep straps
  • 2 Quick-adjust forearm straps
  • Adjustable bottom hem
  • Adjustable Velcro + zipper cuffs
  • Articulated cuff for comfortable interface w/ gloves
  • Soft leather cuff trim for comfort on wrist
  • Jacket-pant zip connection
  • Integrated jacket-stabilizing, removable and adjustable kidney belt support system
  • Rider position articulation
  • Like
Reactions: DS
SOLD via an alternative platform .
Thanks for all the interests and comments on here 👍
