Sold Klim trousers or Gravel pants size 34” wanted
Northern jock
Kingussie
Thinking about some laminated trousers, anyone got a pair of Klim ones size 34” they don’t want?
Adventure Spec gravel pants might do the job as well
Do you mean you’re a 34” waist or you want Klim pants that are size 34”?
The two things are quite different where most Klim kit is concerned…
Right, waist 34” (max)
I’ve got a Badlands jacket which is great though generous sizing
I suggest you try on few models. Sizing is all over the place with Klim. I am 34” waist, 34 Klim was too big. Went for size 32” waist which is spot on. However after lunch I could do with a bit of room. My tailor will do a modification on the waist band also add belt loops.
I have a really high end triple laminated Klim Latitude suite, but don't use the pants much as they're a bit too big for me. They are size 34 (I'm a size 32 but can't quite adjust them small enough for me). They are pretty much a badlands but more road focused. Could be tempted to sell the pants.
Thanks, from comments made above I suspect they’d be a little on the large size for me. If I get the chance to try some on I’ll get back to you
No worries. Like I say, I'm a 32 waist and I get away with using them when I tighten the velcro adjusters to the smallest point, but they are a bit too big for me.. I suspect if you are a 34 inch they'll be bob on. No worries if not 👍
Thanks, I’ve decided to buy some gravel pants and see how the look and fit, I can always return them.
