KTM 1290 TPS Replacement - coding?
(RIP) Bin Ridin
Dublin mostly!
Hi,
My front wheel TPS has become lazy and won't display until the bike has been ridden for c. 20 minutes.
It might come right when the weather warms up. If so, I can wait until a new front tyre is needed and change it then.
Don't fancy changing the battery, did that on BMW and it did not last.
Does anybody know if a genuine replacement KTM sensor will need to be paired to the bike at the dealers, or will it pair itself?
Bin
hi,
i fit a new rear sensor on my 2017 1290gt, it paired itself in a few mins of riding no problem . i think if you change two at the same time it can be diffrent so one at a time is the way to go
Shifty,
Thanks, that sounds good!
Meantime, I have sprung a radiator leak so going to have to replace that now. 87,000kms
Luckily it became apparent as a drip drip drip when putting the bike away after a ride, and before coolant level went out of bottom of bottle.
Bin
Had a radiator leak myself last year, topped up the cooling system with radweld (aprox 50ml) all was sealed after a short ride.
I read somewhere these radiators can crack near the top mounts, so radiator place North (of me) fixes and strenghtens them for a fraction of the cost of a new one - buggered if I can remember who it was though.
Could even have it sorted before it cracks if your that way inclined, but now clocked up 40k on 3 x 1X90's and mates done 70k on his 1190 with the same rad still going strong, so don't see it as essential because "they all do that"
