Chris, Rich
I live in Kent and have a 2000 1150 which died on Feb-28, I've been away since then - I been in China me
) - and am only now looking to put it right. Is there a simple (or complicated!!) test to check if it is the Lambda/fuel contamination problem?
I did use Tesco fuel, I alternate between Tesco and Shell, did about 100 miles after filling up with Tesco, previous tank had been regular shell. I was riding home from work on the motorway, steady speed and it just died, as if I'd run out of fuel. Wouldn't even fire when trying to restart. All electrics worked OK.
If it is Lambda, do either of you guys have an outlet in the South East?
Cheers Jim
