Laser Can/Touratech Panniers..
Urban Rider
Windsor, England
Okay, here's the thing.....
Bought a Laser can and Y piece for my 1150 GSA SE and started to fit it this evening. First problem I encountered was the Lambda Sensor. In the original CAT it screws in to the middle section and points up at an angle. When fitting the Ypiece I noticed the Lambda screws in from the side and further back then the original. Not too much of an issue as I just re routed the cables to make it fit... Right or Wrong?????:nenau (Right to re route or wrong Y piece?)
Next issue is that the Laser can sit's lower on the hanger than the original can. No too much of an issue but I have Touratech Zega's with the section cut out to fit the original can...... What are my options? Do I bin the laser can to ensure the Zega's fit and just replace the CAT with a Y Piece, or fit the laser system and buy new panniers.....:blast
Recommendations please...
